Which gear is more quiet: Motive, or Strange?
Old Nov 5, 2003 | 02:17 PM
stereomandan's Avatar
Question Which gear is more quiet: Motive, or Strange?
I have a couple of questions about rear end gears.
First, is there a noticeable noise difference between Motive or Strange gears?
Is there a noticeable noise difference between 3.73 and 4.10 gears?
Is there a noticeable noise difference between stock gears and either the 3.73 or 4.10?
Why wouldn’t anyone with a M6 get rear end gears? Seems to me to be the best bang for the buck for just about any mod. We’re talking about a 57 RWTQ peak difference between the 4.10 and stock 3.42 gears (assuming 290 rwtq stock around 4000 rpm).
Dan
Old Nov 5, 2003 | 02:27 PM
BUBBA's Avatar
About 10% more tq with 4.10s over 3.73s. Quietest gear probably the OEMs (factory GMs)when set up correctly.
M-6, top gear is a dog with 3.42s and actually does something with 4.10s.
Even with the magnified TQ with lower gearing you are still going to have even more trouble hooking up.JMHO
Old Nov 5, 2003 | 03:03 PM
mongse_1's Avatar
The setup has more of an effect on noise than the manufacturer. I have always heard that Motive's were quieter(and stronger), but again, just what I've heard.
Old Nov 5, 2003 | 03:28 PM
zhevy-1's Avatar
Motive by a landslide.
Old Nov 5, 2003 | 03:35 PM
reuter's Avatar
id say it has to do with the pinion depth and lash being set properly more than the brand of the gear. however, ive heard that a higher nickel content (harder material) can cause the gear to whine more. i had a good friend of mine who is a gear specialist do my 4.10 in my 1995 m6 z28 and it does make a slight noise during acceleration but nothing annoying. the pinion depth was set to exact specs too. it's a strange 4.10 gear
Old Nov 5, 2003 | 04:38 PM
Thanks all.
So the OEM's are probably the quietest? Are the Motive gears the OEM gears?
Where do I find info on a 3.73 or 4.1 made by GM?
Thanks,
Dan
Old Nov 5, 2003 | 04:52 PM
ibanez6rg's Avatar
Yea, but what about strongest?
Old Nov 5, 2003 | 05:06 PM
J's 82's Avatar
Setup setup setup..... the better the setup the lesser the noise, regardless of gear manufacturer...
there are other variables in gear noise too, panhard/lca/torque arm bushing type (poly, heim, rubber), exhaust noise (the louder the exhaust, the lesser the gear noise )...
As for who makes the best gears, can't go wrong with Motive or Richmond.. strongest, well then you get into the 7.5 vs 12 bolt debate, physical gear size is the stength limiter on a 7.5.. though you can build them to take some abuse..
Old Nov 5, 2003 | 05:30 PM
aintno6's Avatar
Just for your information. When ever you goto a 3.73 or higher, your going to get more noise. So dont get ur hopes up. Also if you dont have the allumimum driveshaft, it will at time vibrate at higher speeds.
Old Nov 5, 2003 | 05:44 PM
got_hp?'s Avatar
with 3.73 in an M6.........what speed does 4th gear finish at?
Old Nov 5, 2003 | 07:09 PM
About 112-117 according to www.f-body.org/gears. Somewhere in that range. It seems to calculate that the mph in each gear is a little higher than what I see on my car. My stock '97 M6 with 3.42 in 6th gear does 84mph at 2000 rpm. That's what my gauges read at least. The calculator says it would be 89 mph, and I get 84 on my speedometer, so one of us is off a little.
I'm glad that you brought this up, because a 4.10 gear would finish out 4th at about 103-107. Too early for what I plan for my car. I would like to run faster than that in the 1/4 mile, and that would mean an extra shift with the 4.10 gears.
Dan
Old Nov 6, 2003 | 06:18 AM
IDOXLR8's Avatar
I had Strange Gears in my car that withstanded over 500 rwhp. They were also extremely quiet. But as said earlier the whine will depend on whether or not they are setup properly.
Old Nov 6, 2003 | 07:39 AM
nateh's Avatar
Dan
Consider that if you do anything to make power up higher (cam, valvetrain, heads), you're going to bump the rev limiter. 4.10's at 6500 RPM are going 121. That's perfect for a lot of people wanting to crack into the elevens...
Old Nov 6, 2003 | 08:42 AM
DB75's Avatar
I have Strange 3:73s. I can hear them whine between 50-60 mph. Anything over 60 and my exhaust takes care of the noise. Other than that I'm happy w/ the gears.
Old Nov 6, 2003 | 10:24 AM
Got-LT1's Avatar
I'd say that the biggest factor in how loud gears are is how well they were installed. I have heard Richmonds that are quiet as hell and motives that whine like hell.
