Changing to 160 thermostat
Old Nov 5, 2003 | 01:03 PM
rollinn95z's Avatar
If I change out to a 160 degree thermostat, what do I need to reprogram along with it? Do I need to change the fans to turn on at 160?
Old Nov 5, 2003 | 01:07 PM
Fastbird93's Avatar
Not required, but it helps. Also, due to the car running colder, a tune is recommended so you don't kill your gas mileage. I can't remember the exact reasons as to why, but I do remember seeing it.
Old Nov 5, 2003 | 01:18 PM
rollinn95z's Avatar
Well I've got a new opti, plugs, and wires. The gap for plugs was .050 right?
The only thing I haven't changed yet are the O2s with 105k on them.
Old Nov 5, 2003 | 01:50 PM
You don't want the fans to turn on at 160degF... the t'stat will never fully open. Maybe turn them on at 185degF and off at 170degF.
You also don't need a "tune". The closed loop feedback from the O2 sensors will allow the PCM to correct the A/F ratio due to any change in the intake charge temperature.
You might consider some additional timing, since it will allow you to take advantage of the cooler head temperatures.
Old Nov 5, 2003 | 02:06 PM
rollinn95z's Avatar
Let me throw this out there. I recently replaced the heater core and the radiator. My waterpump was replaced about two months before that. While replacing the HC and R, I removed the oil cooler assembly. I replaced every other hose and didn't want to mess with replacing the ones on the cooler. While I'm driving down the highway, the temp gauge pegs between the quarter mark and half mark. It didn't do that before I did the HC and R. I did burp the system after I replaced them too. I'm just looking to fix that higher highway temp problem, but I'm trying to hash out whether to just put the oil cooler on with new hozes or change down to the lower thermostat.
Suggestions?
What do you think of the red line water wetter?
Old Nov 5, 2003 | 02:09 PM
Red96Lt1's Avatar
I don't mean to steal your thread, but how much does a 160° Stat help? It seems like that cooler air would help power, but cooler combustion temperatures would hurt?
Old Nov 5, 2003 | 05:01 PM
12SCNDZ's Avatar
I'm getting ready to switch back to a 180. My car doesn't like the 160. Water temp never gets above 180 with it.
Frank
Old Nov 5, 2003 | 05:06 PM
got_hp?'s Avatar
Frank
i was considering that too
even in the florida heat, my temp never goes over 175 while sitting at a stoplight, and 165 while driving.
im putting a cam in and having it tuned after, so ill see if i can advance timing to compensate for the low temps.
Old Nov 5, 2003 | 06:01 PM
zoso1959's Avatar
Question
I have a 160 thermostat and here in the windy city where the temps get hot like,
florida,my car temp will begin to rise, I have to manualy turn the fans on
would like to know why your car runs so cool?
zoso
Chicago94Z28
Aug 28, 2002 08:31 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
turbo_Z
Aug 19, 2002 10:50 PM
ericz28w
Aug 19, 2002 07:27 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
