High rpm mis??????
Old Nov 6, 2003 | 07:55 PM
9secbird's Avatar
HELP!!!!High rpm mis??????
I went to give my brother a ride in my car, and all of the sudden i have a horriable high rpm mis, we think its the distributer but were not sure, it wont do it when you rev it, it only does it under a load. any ideas on what else it could be, and if this ever happened to you. thanks
Old Nov 6, 2003 | 10:48 PM
Indy93Z28's Avatar
Yup sounds like an opti problem
Old Nov 7, 2003 | 05:56 AM
MJ_Z28's Avatar
9sec. check your coil and coil wire. if there's a white residue powder on the coil, replace them both. I had the same problem and after changing plugs, wires, coil, coil wire...everything was cool.
good luck.
-mj
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
PhantomTA
Aug 17, 2002 12:19 AM
