Timing marks
Old Nov 7, 2003 | 01:15 AM
Camaroz28lt1383's Avatar
Timing marks
Does anyone have a diagram or picture of lining up the dots and ect. when putting the crank hub on? Thanks for your help Paul
Old Nov 7, 2003 | 01:32 AM
S.J.S.'s Avatar
What year is your car? I'm assuming a 96 or 97 with a keyless hub. Anyway with the dots lined up on the crank and the cam with #1 piston at top dead center, the arrow on the hub should be up. But what I also did with mine is just look into the hub. You should see the marking on the inside from where the keyway should be and line it up. I might be a lil off on this but check before you do it.
Old Nov 7, 2003 | 01:52 AM
Transamdriver's Avatar
Acctually dot to dot is TDC for #6cyl. 12 12 is #1 TDC.
Old Nov 7, 2003 | 02:14 AM
S.J.S.'s Avatar
Nope I don't think so buddy boyyyeeee I just put mine in today brother.
Old Nov 7, 2003 | 02:36 AM
#1 and #6 cyl peak at the same time, the cam determines which one is at TDC.
Old Nov 7, 2003 | 02:37 AM
S.J.S.'s Avatar
Huh.....how does the cam determine which one is as TDC????? Even without the cam in #6 will hit TDC when you turn the crank. That never changes. What you said was 12 and 12 was TDC for #1.
Old Nov 7, 2003 | 02:40 AM
I know that but you said 12 and 12 was TDC for #1.
Correct, cam dot and 12 and crank dot at 12 = #1 TDC.
http://csce.uark.edu/~jgbertr/rb/cam_timing.mpg
Old Nov 7, 2003 | 02:41 AM
S.J.S.'s Avatar
DUDE.....right now I'm looking in my #1 cylinder and that **** is at TDC. You must be just saying it different. dunno dude. There is only 1 way the thing can go on.
Old Nov 7, 2003 | 02:43 AM
Yes and your #6 cyl is at its peak also. #1 and #6 peak at the exact same time, you can bring #1 to its peak then install the timing set "dot to dot".
There is a different between a cyl reaching its "peak" and TDC.
Old Nov 7, 2003 | 02:54 AM
S.J.S.'s Avatar
My bad dude......I was confussing myself. I thought something and ran with it.
Old Nov 7, 2003 | 09:23 AM
grendal's Avatar
He's right. On the LT1 12 and 12 is #1 TDC. Dot to dot is #6 TDC. I figured this out when doing my cam and "dot to dot" made for lots of loose roller-rockers when adjusting the valves, heh.
12 and 12 is #1 TDC on an LT1. Shoebox helped me figure this out
-Michael
Old Nov 7, 2003 | 10:12 AM
Don 97 SS's Avatar
-Michael
I agree with the way Grendal explains it above.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Feffman
Oct 9, 2015 05:42 AM
meissen
Jun 1, 2015 07:59 AM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
