96 keyed crank hub with washer???
I was reading thru some of the posts that the 96 crank hub is keyed vs. the 94. I've also read that the 96 hub is a little shorter.
I know that you can buy a keyed hub but I would like to save a few bucks if I can.
Is it possible to use the 96 hub on the 94 with the correct size washer? Also does the washer have to be keyed as well?
Can this washer be bought some where?
Thanks,
Scott
Thanks,
Scott
No factory LT1 hubs are keyed (any year). If you wanted to use a 96> hub on a pre 96, you would need a spacer that is equivalent to the thickness of the reluctor used for the crank position sensor used on the 96> engines. That spacer would likely need to be keyed like the crank timing gear.
stockssn2o
May 25, 2015 08:54 AM
cyteone
Feb 7, 2015 06:04 PM
