Camshaft question
Old Nov 6, 2003 | 02:42 PM
CatsTasteGood's Avatar
Camshaft question
How will this camshaft work with my 97 lt1 with stage 2 port and polish. 2.02 intake, 1.6 exhaust.
It is a crane powermax
Serious performance for modified 305 5-spd. & 350 w/3.73-up.
Adv. Duration: 272º/284º
Gross Lift: .454''/.480''
Series: 2050
Old Nov 6, 2003 | 02:59 PM
WheelmanZ28's Avatar
It Won't
Old Nov 6, 2003 | 06:49 PM
What would be a good cam? This is a street car and i will have 4.10's in the near future.
Old Nov 6, 2003 | 07:27 PM
Camaro_Maniac63's Avatar
Get your heads flowed, then call the guys at cmotorsports.com, or call Comp Cams, Crane etc.. They will get you a custom grind cam to make the most out of your heads. Good luck.
Old Nov 6, 2003 | 07:33 PM
grendal's Avatar
I think that cam would suck on an LT1. It's for a 305, right? That would explain the low lift and long duration... You need more lift, basically.... Is that even a roller cam?
Skimp on something else. Get a good cam.
-Michael
MadMav
May 25, 2015 09:35 PM
Red_94Formula
Jan 22, 2015 12:17 AM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
