EGR and AIR block off?
Old Nov 4, 2003 | 04:28 PM
97Z-pimp's Avatar
Arrow EGR and AIR block off?
This weekend Im going to be installing my Jet Hot LT's and wont be keeping the EGR or AIR. I know i will need some block offs for this but what exactly do i need?
Old Nov 4, 2003 | 04:52 PM
Hyperspeed97z28's Avatar
For EGR you may need these : http://www.mycamaroz28.homestead.com/
Old Nov 4, 2003 | 06:51 PM
97Z-pimp's Avatar
I heard that you could possibly crimp the metal line before the EGR, is that true or not?
Old Nov 4, 2003 | 06:56 PM
Mystic97Z's Avatar
i may be wrong,,,but
blocking the egr stops the hot air from the headers from being pulled into the intake right?
i heard from a technician that although the air from the headers is very hot,,its cooler than the air inside your cylinders, which is the egr's purpose right? to cool down the air in your cylinders? thats why i didn't block mine off, its on there for a reason.
Old Nov 4, 2003 | 08:16 PM
CrippleFightin's Avatar
I do believe the purpose of the EGR is to recirculate the exhaust back through again to burn off more of the pollutants. I dont think it has anything to do with cooling the cylinders.
Old Nov 4, 2003 | 09:10 PM
1msfyter's Avatar
For the smog ****'s Couldnt you just block off the pipe from the exhaust into the intake with a plate and still keep it stock looking?
Old Nov 4, 2003 | 10:01 PM
Mystic97Z's Avatar
i'm pretty sure the egr system cools off the air inside ur intake,
Old Nov 4, 2003 | 10:13 PM
The EGR system is used to lower NOx (oxides of nitrogen) emissions caused by high combustion temperature and excessive oxygen. Adding exhaust gas displaces oxygen and decreases combustion temps. It does provide some cooling effect, but not in the typical way.
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
