What exactly is the diff in an lt1 block and a standard sbc block?
Old Nov 7, 2003 | 01:27 PM
bradpreece95z28's Avatar
Please tell me, I have wondered the exact differences for a LOOONG time.
Old Nov 7, 2003 | 01:37 PM
hot_red_z28's Avatar
well, first off, with a different intake, it would probably have slightly different port locations, and has the square (roughly square) exhaust manifold ports...
Also, not sure if a structural difference is needed for this, but the LT1's are reverse cooled, meaning the heads get cooled first, then the block...
Old Nov 7, 2003 | 01:39 PM
Yeah, I was aware of the reverse cooling and all, ad the intake ports.
What I am actually looking for is the structural differneces
Old Nov 7, 2003 | 01:41 PM
sorry, but i'm not really sure about the exact architecture of the block, and how that is different from others...
Old Nov 7, 2003 | 01:43 PM
S.J.S.'s Avatar
Not all Lt1's are reverse cooled. Only a couple of years...I believe 96,97. Could be wrong as usual.
Old Nov 7, 2003 | 01:46 PM
I think all newer ones are. my 95 is and I have seen many 93s that are.
The lt1 has been around for MANY years, I am just trying to gain some exact knowledge on the topic.
Old Nov 7, 2003 | 01:49 PM
i'm fairly sure that all LT1's are reverse cooled, at least the ones with aluminum heads anyways...
Old Nov 7, 2003 | 01:55 PM
ibanez6rg's Avatar
All them mumbo-jumbo's are reversed cooled!
Old Nov 7, 2003 | 01:59 PM
ClawSS's Avatar
All of the late model LT1s are reverse cooled. Including the '92 Corvette - '97 F-body with the 94-96 Impala SS thrown in for good measure. Iron heads and Al. heads made no difference in the cooling direction.
As for the other differences, possibly in the oil passages and water passages for the water pump along with the dry intake...etc.
Old Nov 7, 2003 | 02:58 PM
Where do you come up with this stuff?
The biggest, most obvious difference is the cooling system. The LT1 intake is dry, compared to the older SBC. Water pump to block and head to block passages are different. Steam pipes from the back of the heads because of the reverse flow system. Front mounted distributor. Rotating assembly geometries are the same as the SBC, AFAIK. Basically, it is the last modified iteration of the SBC before they went to the all new design of the LS1.
Old Nov 7, 2003 | 07:55 PM
S.J.S.'s Avatar
How else can I get you to chime in??? Hey shoe I thought only the later ones were.......like the 93's and up. Well my machinist set me up again.
Old Nov 7, 2003 | 07:58 PM
Transamdriver's Avatar
And since it is reverse cooled the water passages in the block are also different.
Old Nov 7, 2003 | 09:37 PM
JDBlaze85's Avatar
only the SS models are reverse cooled!
Old Nov 7, 2003 | 10:20 PM
NewbieWar's Avatar
Every lt1 is reverse cooled, this cooling allows for higher compression and wouldnt be an lt1 without that compression
Old Nov 8, 2003 | 10:37 AM
96 WS6's Avatar
It was a joke man...
D1SC383LT4
Jan 26, 2015 01:41 PM
ddr698
Jan 9, 2015 10:05 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
squinn
Aug 4, 2002 01:06 PM
routesixtysixer
Jun 23, 2002 02:29 PM
