can computer go bad-car wont start
Old Nov 5, 2003 | 12:14 PM
jeremy reppert's Avatar
one day the car quit running. checked all the relays,fuses ,fusable links. Got a new battery, ignition switch & keys, and starter. Well i took the whole dash apart and started unplugging things and putting them back together and the car finally started. I put the dash back together and went to work and the car wont start again. no accessory power, no ignition power or fuel pump. I was told that it can only be that pass key decoder module or the computer. the wiring in the caris perfect and all connections are clean. Any suggestions are appreciated.
Old Nov 5, 2003 | 12:37 PM
Z28SORR's Avatar
Year, make, model of car??
Old Nov 6, 2003 | 02:00 PM
95 z
Old Nov 6, 2003 | 03:35 PM
If you are not getting any power to the dash for the gauges or idiot lights, it's probably the ignition switch (on the steering column, under the dash). If needed, there is a guide on my Tech Page for replacing it.
Old Nov 7, 2003 | 12:51 AM
thanks shoebox but i already replaced it and still nothing.
Old Nov 7, 2003 | 03:24 AM
PredatorZ28's Avatar
check the acc fuse ..... again thats what happend to me
Old Nov 7, 2003 | 07:52 AM
Hmm... you said switch and keys. Did you replace this or the key cylinder?
Old Nov 12, 2003 | 04:53 PM
thanks Shoebox, you are the man!!! It was the switch, it was burned and looked like the one on your tech page. Im gonna go get a new switch tommorrow to see if it works. thanks!!!!!!!!!!
armedtrigger
Feb 24, 2015 08:30 PM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 18, 2015 08:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
