what cam to use
Old Nov 5, 2003 | 01:46 PM
97 FIREHAWK's Avatar
Lightbulb what cam to use
i have a 97 lt1 car i want to put a small cam in it that will run off stock heads and stock computer what cam would be the best to run and need some one good and cheap to install the cam
also how can you till if the opti spark is bad
Old Nov 5, 2003 | 01:50 PM
Fastbird93's Avatar
The first ones that comes to mind that have a good balance are the 218/224 XE or the CC305 or the Hotcam if you're not doing the heads. It's well matched to the flow characteristics of the heads. Granted, there's guys out there driving on stock heads with MUCH bigger cam profiles, but there's an inherent amount of lost driveability with these also.
As for the opti, there's tons of things that get misinterpreted as the opti, so there's really no set way to tell other than putting the car on a scanner or the like.
Old Nov 5, 2003 | 02:05 PM
BUBBA's Avatar
"Good n Cheap"? or "Good" and "Cheap"?
Old Nov 5, 2003 | 02:17 PM
BUBBA's Avatar
Cam install isn't rocket surgery, however, if you aren't careful and knick it or something, you are going to have some nasty problems.
The 210/224 cam is PCM friendly, very drivable and maintains good low-midrange TQ.
If you need "cheap" get some bigger RRs(at least on the exhaust side) + some better springs and you can do it yourself).
Many mechs. will charge between 700-1000 for a cam install (not counting RRs and springs) and if you can't afford to do it right, don't do it.JMHO
Old Nov 5, 2003 | 02:24 PM
FacelessZ's Avatar
lol @ rocker surgery
Old Nov 5, 2003 | 02:25 PM
Terran2k's Avatar
just curious, what motor's came in 97 firehawks? lt4s?
Old Nov 5, 2003 | 02:28 PM
FacelessZ's Avatar
LT1's and I believe a select few had LT4's...
could be wrong....
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
