What would you do for a good tune up?
Sounds like you about have most stuff covered. I'd say oil, diff oil, dont change the trans fluid unless its dark and/or burnt smelling. Check your belt. Pull the throttle ducting off and clean out your throttle body with some cleaner. I usually hold it open and use a screw driver with a rag doused in cleaner to get all the gunk out. Other people may have more ides on stuff. Hope I helped.
Originally posted by jasons93z
Coil=yes. Opti=NO. There is no reason to go through all the labor if its not broken.
Fbodfather
25
Jun 21, 2002 04:12 PM
