who used NGK spark plugs
how good are the NGK TR55 plugs? do they help with performance or not. what other plug is out there thats better. has anybody tried the platinum TR55's or the iridium let me know how they worked out
then you would go to a TR6...
I have long discontinued my use of NGK spark plugs.
Had one crack and break on my while doing a burn out on the staging lane.
Had multiple plugs back out of my heads.
Had a couple of the tips on them back off.
Switched to Autolites.. Been smiling ear to ear ever since.
Originally posted by Smoke T/A
NGK here for 7 years. Never had any problems like above. sounds like they were not installed properly if they back out.
if you do a search that is a problem that has happened to several people that use NGK's.. im not the first
I use the Autolite 104 plugs. They run clean. I used to use the TR-55 with no luck. After a trip into town they would foul and my car would feel sluggish.
A friend of mine told me to buy the Autolites. After I switched I was telling him how much cleaner they run and he told me a story about a motor he dynoed. He said it was an all out big block that used NGK race plugs. He changed to the Autolite non-resistor plug and the motor gained 4 HP. That is a good bit of power for a plug change.
racecarz28
Mar 30, 2015 09:55 PM
it's just a mod that's gonna help u NOT loose horsepower
