what bolts to use with lca's??
Old Oct 2, 2003 | 11:17 PM
lt1camaroman93's Avatar
I just got my bmr lca's and i order the harware but they sent me the hardware for subframe connectors. i need to have the lca's installed for saturday. where can i get a set of bolts to just throw in there for the day? This is just incase i can't get the stock bolts off in one pice.
Old Oct 2, 2003 | 11:52 PM
96LT14u2Nv's Avatar
i was going to say use the stockers but i wasnt thinking about them breaking off (seen it happen many times). i have no part numbers for ya but i would recommend going to your local hardware or auto parts store with one of the old bolts and match them up to some new ones. i dont know of anywhere that sells just bolts for LCA's
Old Oct 3, 2003 | 04:55 AM
InjectedSS's Avatar
Pulling 1.4 60's here with my STOCK LCA arm bolt's. Never heard of anyone breaking a LCA bolt
Old Oct 3, 2003 | 05:52 AM
woried about having to heat them up and breaking them when i try to take them out.
Old Oct 3, 2003 | 06:00 AM
InjectedSS's Avatar
What? Heat them up
Dude you remove the nut and then tap them out, why would you need to heat them up
Old Oct 3, 2003 | 06:15 AM
heat the nut up to get it off.. last time i tried to take them out i was haning off of the darn bolt with a 1/2 drive ratchet with a 2 foot braker bar on it and nothing.
Old Oct 3, 2003 | 07:42 AM
I've never had any problems with the stock bolts, or seen them break. But if yours are corroded as badly as you indicate, replacement makes good sense.
(4) 12mm Grade 10.9 bolts (silver zinc plated)
(4) 12mm steel lock nuts (silver zinc plated)
(8) 12mm flat washers (silver zinc plated)
Spohn Performance sells the above kit for $10.
96SilverRam
Nov 20, 2016 11:19 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
maybe2fast
Mar 16, 2015 09:45 AM
