where is the oil pres sending unit
I need to change that tommorow... where exactly is it located? and is it gunna squirt oil at me? (obvisouly gunna do it when the car isnt running which means it shouldnt be squirting anyting, but i just wanna make sure)
Sending Unit
The Oil pressure sending unit on the lt1's is located on the very top of the engine near the back on the intake. You can't really see it from under the hood, but you have just go to reach back and feel around for it. They are about 3 inches long of black plastic and they break very easy. I broke mine during a tranny swap, but the local Napa had one for like 30 bucks. We had my tranny in before we noticed, but I managed to do it from the ground just by reaching behind the intake. It's a little tricky, but not bad.....
Isn't everything tricky under the hood of an F-body??? T
That’s the best description I can give you but I can pry help more if you give me a specific question....
jess@macconline.com
jess@macconline.com
ok, i'll look for it tommorow when there is light... i got one from napa for 21 bux... hope that'll fix my oil pres gauge problem
they look cheap like u said :P
is it gunna squirt crap at me tho? (do i get it out under the car or top of the car :P)
You should be oil free if you let it cool down. There should not be any pressure at the sending unit unless the engine is running as the sneding unit gets its feed directly off of the pump.....
if you have any problems like I said, just email me.....
Jess
Jess
I have a 93 Z-28. Shoebox, thru your picture noted above I see that a "note" says the oil sending unit is near the oil filter on my 93. Thanks for that note.
Anyway, my oil gauge is erratic. In other words it goes all the up way past 80 PSI then goes to the normal range then in a few moments it goes low, then past 80 again. Its really unreliable. If I change the oil sending unit will that solve my gauge problem too?
Thanks,
Jeff
Thanks,
Jeff
Thanks,
Jeff
Thanks,
Jeff
Yours could be just a connection problem. I would check that at the sensor, first. If that looks good, then replacing the sensor would probably be next.
