After H/C install "no" heat
Old Oct 3, 2003 | 09:24 AM
TransAmMan's Avatar
After heads and cam i now dont have any heat. I have a 160° stat in it, but i had that in it before and i remember havinghotter heat. Now the temp guage gets up to about 180° and i still dont have heat.
How can i fix this? Whats wrong?
Old Oct 3, 2003 | 09:38 AM
FireAm94's Avatar
Did you check the vacuum line on the passenger side of the intake?
Joe
Old Oct 3, 2003 | 10:23 AM
InjectedSS's Avatar
you coolant isn't bleed right. Best thing to do is BEFORE you install the t-stat, I always like to fill the coolant right there where the t-stat goes, that way you fill the engine with coolant that drained outa there. Cause if you think about it there's NO coolant in the waterpump when you first put it back on, so when you fill the system back up the waterpump has no coolant to move around yet. Just fill it up completly and start the car and open op those bleed screws and that should help.
That's definately your problem though
Nov 18, 2023 07:21 PM
Bignasty85
Mar 3, 2015 04:05 PM
Jan 23, 2015 01:13 PM
ro2207
Dec 4, 2014 06:18 PM
Ken95Z28
Aug 21, 2002 04:32 PM
