Big Problem with my new SLP clutch
Old Oct 3, 2003 | 09:52 AM
Shawn W's Avatar
Ok so i just did a M6 swap on my 94 Z28. The swap went fine and we had no problems.
After getting everything done the car vibrated really bad when you got above 3500 RPM's and was on it. If you just drove around normally it was fine but when you got on it at higher RPM's it would vibrate. After smelling burning cluthch it was determined the clutch slipping was causing the vibration as it was trying to grab but was slipping.
Pulled the clutch back out and here is what we found.
On the pressure side of the pressure plate The inner most part of the pressure plate(part closet to the hub) is blued and burnt. The outer edge of the pressure plate doesn't look like it is even making contact with the disc. The disc looks like it is only grabbing on the inner most edge also. The flywhel looks the same way. It is blues all around the innder egde but doesn't look like it's making contact around the outer ede.
I am using all stock original master and slave cylinder. Had the stock flywheel resurfaced. Is it just a faulty pressure plate or something in the car that is causing it?
Shawn
Old Oct 3, 2003 | 10:33 AM
zjet's Avatar
i would call who you got it from.also theres a balance mark on the flywheel and pressure plate did you get them matched.i had a problem when i put centerforce in.
Old Oct 3, 2003 | 10:35 AM
InjectedSS's Avatar
Yea this is why people give these clutch's a bad name cause they don't install them right. MAKE SURE you ligned up those mark's correctly.
Old Oct 3, 2003 | 10:42 AM
Shawn W's Avatar
Well i had a shop do the install. They have done lots of clutches for people i know. I assume they would know about this but i will ask them to make sure.
Also could a bent clutch for or worn out slave cylinder cause a problem?
Shawn
Old Oct 3, 2003 | 10:49 AM
Shawn W's Avatar
Hey injected SS where is the rest of my exhaust man, I have tried and tried to contact you but you won't respond to any of my PM's I really need to get in touch with you. Please go read your PM's or if you already have and are just ignoring me i am going to take the action described in my last PM to you.
Shawn
Old Oct 3, 2003 | 10:55 AM
InjectedSS's Avatar
Shawn
What PM? You need to clean out your inbox. Send me an email
Old Oct 3, 2003 | 11:30 AM
Shawn W's Avatar
I sent you some mail InjectedSS please get back to me.
Anyone else have any ideas on my clutch problem?
Shawn
Old Oct 5, 2003 | 01:35 PM
Shawn W's Avatar
about this balance mark on the flywheel and clutch. What does it look like? will the clutch bolt up if the balance marks aren't lined up? Does it apply with a aftermaket clutch?
I asked the shop that did the clutch install and they said they didn't notice any balance mark and told me that it will only bolt up one way probably. I noticed on the edge of the pressure plate there are little blancing holes drilled into some of the metal.
Please tell me or show me what these balancing marks look like so i can make sure this don't happen again.
Shawn
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
slothgrant
Aug 22, 2002 03:01 PM
