Supercharged LT1 Rebuild
Old Oct 2, 2003 | 08:12 AM
MikeW's Avatar
The car is a 95 LT1 Z28 with a 5psi Paxton supercharger. Other than roller rockers the internals were completely stock.
Detonation destroyed 5 of the pistons, so the motor has to be rebuilt. The car is street driven, but raced a lot too.
1) Is there anything that should be changed or done to the motor before re-assembly?
2) What kind of pistons would you use? Forged or Hyperutectic?
3) Compression was 10.5:1 (plus whatever the Supercharger was adding). Should it be lowered?
Any help would be greatly appreciated
Old Oct 2, 2003 | 08:48 AM
95 Silver TA's Avatar
You should post this question in the "Forced Induction" of this FORUM you will get a lot more detailed answer over there.
But to answer some of your questions,
Yes forged pistons is the only way to go when doing a build up for a blower and dropping the compression will also depend on how much power and boost you are planning on. If you are planning on running 5 pounds later, then I would only drop compression about a 1/2 a point with forged pistons...If you are planning on running a LOT more boost then I would drop compression down to 8.5:1 to 9:1 compression.
Also another key to making good power and keeping your motor in one piece is a good tune, you will definetly need a good Dyno Tune or Good Street Tune. I had Bryan at PCMforless personally street tune my car. A bad tune could lead to another rebuild (sooner than you think).
Hope that helps,
Claude
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
tubby
Oct 13, 2003 09:16 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
