whining sound in rear end
Old Oct 2, 2003 | 06:04 PM
Donohue96M6Z28's Avatar
on my 94 z28 i can hear a faint whining sound in the back ...im pretty sure its the rear end...i can barely hear it though and when i turn the wheel it gets a little bit louder and when im accelerating i can barely hear it but i can hear it...i know it as to do with my rear end but i was just wondering. i know none of you guys know exactly to what extent my problem is or know what it is exactly but do u have a range of $ it would maybe cost to fix it...or any ideas of what it is exactly..thanks for your help
Old Oct 2, 2003 | 06:19 PM
RamAir95TA's Avatar
A small amount of gear whine is pretty normal.
Whining is acceptable.
Howling is not.
I wouldn't worry about it. Until you can hit the gas and not move, don't sweat it. A gear swap would cost you $200 for the gears, and about that much more for labor.
Old Oct 2, 2003 | 06:30 PM
ya man i used to have another z28 and never did the whining...do u think a gear swap would maybe fix it?
Old Oct 2, 2003 | 06:31 PM
NegativeCreep's Avatar
My rear end was allways quiet then one day I noticed a whining noise, most noticeable on decleration. Two weeks later I hit 2nd gear real hard and bye bye 10 bolt.
Old Oct 2, 2003 | 07:38 PM
Aeromaks's Avatar
Yep, whining rear end, esp when turning, get ready for ten bolt to go, so save up for a 12 bolt, or......for a new posi unit/gears, when you do a burnout, do both wheels go or just one?
but yeah, happened to me last year. just take it easy on the car, else you will be stranted.
Old Oct 2, 2003 | 08:48 PM
how much would it cost once it goes ...estimate...
Old Oct 3, 2003 | 07:28 AM
Everthing cost me about 450, thats with buying used gears off a board member. The rear end guy told me it would have been cheaper if I had taken it to him sooner instead of waiting until it blew up.
Old Oct 3, 2003 | 08:25 AM
93zguy's Avatar
i hear the same whining sound but only when i go around a tight corner any ideas?
Old Oct 3, 2003 | 12:18 PM
CoUnTryMuZiCZ28's Avatar
change oil and check u joints.. change it twice once and then change again in 500 miles to get everything out.. i HAD a whine.. the only whine i have now is when the GF is in the passenger seat.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
