Washing your camaro...
Old Oct 3, 2003 | 04:32 PM
Chevycobb's Avatar
I was told that cleaning the engine can ruin the opti because it will get wet...is there an easy way to get the engine looking clean without pulling it and cleaning it, and without screwing up the opti? Also, a friend of mine has the "salad shooter" rims on his Z28 and he used, I think, the Turtle Wax Wheel Cleaner, and it left faint, white streaks on his rims. What caused that and what is a good wheel cleaner that you guys have found to be good?
Old Oct 3, 2003 | 06:06 PM
1msfyter's Avatar
Simple green cleaner and a spray bottle with water. Lots of rags
and you can get this:
http://www.bealer.org/wire2.jpg
http://www.bealer.org/wire.jpg
Old Oct 3, 2003 | 06:18 PM
Lyle A's Avatar
You forgot Lots of time!
Old Oct 3, 2003 | 06:31 PM
1msfyter's Avatar
time and bandaids
Old Oct 3, 2003 | 06:54 PM
ZLT195's Avatar
When using an All Wheel type cleaner or any type of cleaner, NEVER let it dry! When you let stuff like that dry you get nice white streaks or white water spots the same goes for Simple Green.
Its also the same when you wash your car let the suds dry on the paint and your gonna have nasty water spots to contend with.
Maybe I'm lucky but I have rinsed off the motor and engine compartment so many times its staggering and never had an opti problem. I would say that spraying directly on the opti might cause problems but the thing has to get wet while driving in the rain so I'm sure that a little water isn't going to hurt it just, drenching the thing would and try to keep the cleaner away from it.
Z~
Old Oct 4, 2003 | 05:10 AM
Eliminator's Avatar
I have washed my engine area several times and never had any problems as of yet I hear horror stories of this but then again its not like I soak the engine just a brisk rinse.
Old Oct 4, 2003 | 11:54 AM
EDS Z28's Avatar
Do not hose down the engine
It is not worth the risk of screwing up the distributor. It happened to me once, never again.
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
Black Sunshine/ 00SS
Jul 29, 2002 03:00 PM
