how to access passenger plugs/wires?
Old Oct 2, 2003 | 11:21 PM
reuter's Avatar
can somebody give me some tips on how to access my passenger side plugs and wires? i have a huge arc going on back there (havent determined which cylinder its coming from so i guess ill just have to look for burn marks) and need to work it out. its makin the car run terrible
ive heard to pull the starter, but i am not sure how to get it back on i mean how do i tension its drive belt properly? some suggestions would help a lot! thanks!
Nick
Old Oct 2, 2003 | 11:39 PM
firepheasent's Avatar
???????????drive belt for the starter????????????????? You must mean the Alt??
Disconnect battery,
Remove Serp belt ( its a spring loaded tensioner )
Remove Alt
Remove bolt from PS motor mount..Yes remove it!!
Jack up on a secure spot on tranny or motor and the motor will roll up 3-4" and give plenty of access to play arround.
Do not try to remove your Y pipe unless your ready to purchase headers...Bolts snap a Y pipe connections 80% not matter how much penatrating oil you use.
Old Oct 2, 2003 | 11:49 PM
96LT14u2Nv's Avatar
it really isnt necessary to jack up the motor IMO. just pull the altenator and the starter and get them all from underneath.
although, i guess if u have manifolds it may be harder. i have only changed mine since the longtubes so i have no experience with stock manifolds. sorry. happy wrenching!!!
Old Oct 3, 2003 | 08:52 AM
reuter's Avatar
Disconnect battery,
Remove Alt
haha yea i realized that after i made this post but didnt get to edit it. alternator not starter. how do i go about taking off/getting the serpentine belt back on?
Old Oct 3, 2003 | 09:13 AM
GREGG 97Z's Avatar
It's very easy to remove. First pull the car up on some ramps, that is the safest way to support it and to get room to access the belt. Then use a socket wrench with a short extension and a 1/2" socket and pull down on the belt tensioner pulley (the one next to the a/c) to get slack in the belt then remove the belt. All you really need to do is move the belt off of the alternator, if you have someone up top to do that it might help. Then you don't have to worry about re-routing the belt when you go to reinstall it.
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
football4life
Oct 4, 2015 07:48 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
surreybrad
Aug 10, 2015 09:34 AM
