383 stroker lt1 (fuel injector question)
i plan on upgrading my 93 camaro z28 lt1 to a 383 stroker with this kit right here http://www.excessivemotorsports.com/product.phtml?p=301
how many lbs should i upgrade my fuel injectors too??
also would i have to get a new pressure regulator or fuel pump to do this?
sorry it's my first engine upgrade...
so far i have a borla catback
k&n intake system
bbk 52 mm throttle body
k&n intake system
Originally posted by theendofsound
i was told by someone that 11:1 is too high for pump gas???
what octane would i need for 11:1?
would there be a horsepower difference between 10:1 and 11:1?
will i need a new fuel pump or fuel pressure regulator if i put 30# injectors on?
Re: 383 stroker lt1 (fuel injector question)
[QUOTE]Originally posted by theendofsound
[B]i plan on upgrading my 93 camaro z28 lt1 to a 383 stroker with this kit right here http://www.excessivemotorsports.com/product.phtml?p=301
I have a 396 stroker that was built by Modern Musclecar with 10.5 or 11.0:1 compression and they put in 30# injectors and Edelbrock 58mm TB. It is also set up for a 200# NOx shot, so I doubt they'd put in injectors that wouldn't be able to handle the increased fuel demand. I don't know if I have a larger fuel pump in it, but I have a fuel pressure gauge and it reads 40# consistently.
I run on Mobil Premium gas (93 Octane) with no knock retard and the car pulls like a freight train.
