heads and cam? (for a 383 kit)
what heads and cam would you suggest with this stroker kit?
http://www.excessivemotorsports.com/product.phtml?p=301
i'm looking for something decently priced...
would i be better off with just the kit for now or would they help alot?
summit has a handful of different comp cams, check out thunderracing.com, they tell you about each cam somewhat. I guess you would probably want to consider swapping your stock heads too with that stroker kit.
I'd say I'm not the one to ask. I'm on here right now trying to figure out what setup everyone thinks I should go with. I'll let you know what I decide though. Are you rebuilding because you want to or because you have to?
