Advanced OBDII Question
Old Oct 2, 2003 | 02:56 PM
96_pimped_out's Avatar
Does anyone know what protocol a '95 Z28 uses? PWM, VPW, or ISO?
What I'm getting at - Do I need anything besides a cable and software? (PWM and VPW require a hardware interface)
Cable I intend to get:
http://www.scantool.net/obdii_cable.htm
I've found several software packages including everything from 'freescan'
Old Oct 2, 2003 | 03:08 PM
madwolf's Avatar
First of all, your 95 is OBDI.
The connector is OBDII. Contact Andrew @ akmcables.com and he'll hook you up with a cheap cable.
96+ GM cars use VPW.
Old Oct 2, 2003 | 04:14 PM
Not to argue with you, because I don't know anything beyond what I've researched today... but according to OBDII.COM a '95 Camaro/Firebird is one of very few '95 vehicles that is fully compliant.
http://www.obdii.com/connector.html
Engine Family | Manufacturer | Model(s) | Fully Compliant?
S1G3.8V8G1EK | GM | Camaro, Firebird | Yes
What you say does make sense, because I went today to AdvanceAuto and they plugged in an OBDII tester and it kept giving an error that it could not connect. So - are you 100% certain about this?
Old Oct 2, 2003 | 04:36 PM
madwolf's Avatar
Those are California models only. Although their programming is very similar to a 96's programming, the PCM is still OBDI.
Am I sure? Well, this is what I do for a living...
Old Oct 2, 2003 | 04:39 PM
jim88iroc305's Avatar
Cool
Old Oct 2, 2003 | 05:02 PM
Not even the CA dual cat A4 models are OBD-II. That "list" has a "typo" in it. If you look carefully at the number, it is for the 3.8L V6, which they incorrectly typed as 3.8V8
To satsify yourself, look at the emissions label on your radiator cover:
Here is the one from Rob/Shoebox's 1995 Z28.
grgguy
17
Feb 23, 2015 07:57 PM
rwferguson43026
Feb 6, 2015 10:06 AM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
squirrels
Jul 13, 2002 01:58 AM
