Cold Air Intake Temp.
Old Oct 3, 2003 | 09:28 AM
John Gloyd's Avatar
Hi All,
I have a quick question. While running some tests last night, I noticed that my air intake temp was 110deg while driving. I have my CAI down in the fender which I believe is the normal place to put it. What temps are you guys seeing? Should I have modified the plastic skirting surrounding the area to allow more air? What is the best technique?
F-Body drivers are: SMARTEST ON THE PLANET
____________________________________
Green 96' z28, M6, BBK TB, GMS MAF, K&N CAI, Flowmaster cat-back, 1LE Elbow, B&M ripper, Accel 9000's, NGK TR55's, MSD A6, Accel super coil.
Old Oct 3, 2003 | 09:30 AM
Where is you IAT sensor located? If it's still in the stock location on the inlet bellows, it is getting "heat soaked" and showing a temperature higher than the air actully flowing in the system. That is why some people chose to relocate the IAT sensor closer to the filter with a CAI.
You did install the "blockoff" plate, to keep hot engine compartment air from getting to the air filter?
Old Oct 3, 2003 | 10:03 AM
John Gloyd's Avatar
I just got the car and all the mods were in place I will need to check this when I get off work.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
