Increased trap speed with a 4.11 gear?
There is no promise of a MPH increase. As a matter of fact, I quickly ran a couple of simulations with your setup through Drag2000, and your trap speed did not increase, and the ET suffered due to worse traction on street tires.
If your car can truly take advantage of spending more time in the upper RPMS, AND, you can hook off the line, then go for the 4.10s. But try to remember that you want to gear your car in a way that will place it's acceleration curve into the range in which YOUR engine makes optimum power.
z28kid93
Aug 22, 2002 04:40 PM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
Camaro90RS
Jul 23, 2002 07:57 AM
Ill be using a ford 9" and I will be able to take advantage of the traction...
