4L60E Stall
Old Oct 1, 2003 | 06:44 PM
WhtLT1's Avatar
4L60E Stall
Hey was wondering what is involved in switchen out the stall to a bigger one? Want to get it done but dont' know what kind of stuff I'm lookin at here. And how lond would it take? The trans is still in the car. Need to drop the trans change the converter and put it back up. what kind of time frame am I lookin at? Thanx
Old Oct 1, 2003 | 07:23 PM
Ken95Z28's Avatar
First need to decide which stall to get, that pretty much depends on the feel of it. The typical street stall to get is a 2800 stall.
If you go any higher and you have an OBDI system you stand a risk of the 1-3 shift problem. Programming is the only way to get rid of it.
If you can do it yourself you can save a few bucks, typically it cost about $200-$250 to have someone do it.
Typical install time depends on type of equipement that you have, plan on at least 4-6hrs. There is alot in the way the must be removed before the tranny is dropped, driveshaft, disconnecting the converter, transmission lines than carefully lower the tranny down. Just take your time, it's a fairly painless job, but messy.
Old Oct 1, 2003 | 07:37 PM
Transamdriver's Avatar
I found that if you just disconnect the line from the radiator and the one that has a clamp in front of the engine, then take the lines out of the holder on the oil pan that the lines have enough room to drop the tranny enough the get the converter out. It saves a whole lot of time and headache than dealing with those pesky clamps on the side of the tranny.
IMO if you can find someone to do it for $200 or less then do it. I smelled like ATF for a week. Not to mention the mess it makes in the driveway.
Nayr
Mar 3, 2023 08:34 PM
4586
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
SEOJustin
Sep 24, 2015 04:39 PM
