what are symptoms of bad opti?
Old Oct 2, 2003 | 10:15 AM
NewbieWar's Avatar
JUst as question states what are some simptoms of bad opti?
Old Oct 2, 2003 | 10:39 AM
NewbieWar's Avatar
any other problems cause i dont have any of those
Old Oct 2, 2003 | 11:38 AM
doodad's Avatar
I had rough running, multiple misfire SES code.
Old Oct 2, 2003 | 11:50 AM
Umbrae's Avatar
Check your plug wires, plugs, coil, and coil wire first.
Usually when the opti starts to go, it has a low rpm stumble.
-CAm
Old Oct 2, 2003 | 12:02 PM
NewbieWar's Avatar
deffinatly got the low rpm stumble... got a high rpm stumple too...
between 5400-redline it will almost decelerate, giving me wiplash type of motion when the car decides to shift, instead of just putting me into my seat like it will when its cold
Old Oct 2, 2003 | 12:09 PM
Umbrae's Avatar
That sucks man. Welcome to the club. My car has a low rpm stumble, makes the whole car shake, but as soon as 2000rpm rolls around, boom... the car takes off. It used to miss throughout the rpm band all the way up to redline, but it hasnt done that at all recently.
Sounds like you need an opti.
Just to be sure, check your fuel filter, your egr valve (they tend to carbon up) and you fuel pressure at the rail. Opti's are expensive!
-Cam
Old Oct 2, 2003 | 02:41 PM
revtime's Avatar
The cap and rotor can go bad on the optis without the optical portion itself being bad.
I recently changed mine out because of a low RPM stumble and backfireing under load. The optical portion was fine but the cap and rotor were shot, the bearing in the opti was kinda loose as well so I put in a complete new unit.
Solved all the problems, well I did have to change the fuel pump as well but thats another story.
Old Oct 2, 2003 | 05:31 PM
Pro/Street SS's Avatar
Cool
Check for a low resolution code...bad news for a opti
Old Oct 2, 2003 | 06:39 PM
96 WS6's Avatar
6 optis??? don't you think the problem is not the opti if it has broke 6 times? water pump? incorrect installation? Those two come to mind.
Old Oct 2, 2003 | 08:45 PM
NewbieWar's Avatar
how much did it run u to get it replaced?
you said a coolant leak, i just fixed one... so maybe that might have cause it to break or something like that
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 10:30 PM
