Best way to do a data log run?
Old Oct 2, 2003 | 01:25 PM
GREGG 97Z's Avatar
I'm working on fixing a stumble that occurs intermitently throughout the rpm range and I just got a program and cable to download the data from my Autoxray scanner to my PC. I was out last night logging some runs with it and was wondering what is the best way to do it. Do you run through each gear to redline (M6) or leave it in say 3rd or 4th and go from a slow roll to redline? It likes to go through the gears pretty quick with the 4:10's and the cam, just wondering what is the best driving method for gathering info when trying to diagnose a problem.
Old Oct 2, 2003 | 01:32 PM
LWillmann's Avatar
I would have to recommend that you do it both ways so you can get a look at how it acts under differing driving conditions.
rumair's Avatar
i'd run it from ~2500~ rpm in 2nd to the top of 4th.
Old Oct 2, 2003 | 02:28 PM
GREGG 97Z's Avatar
I guess I'll try a few different methods. It actually wasn't even missing bad last night when I took it out for a test run That figures. Thanks for the suggestions.
Old Oct 2, 2003 | 02:38 PM
NVetro's Avatar
Log one file in the city, normal driving, lots of stops and does. and the 2nd run go on the highway and go through each gear and high rpm, do like 2nd gear romps and let off mid-top of 4th, which is what i did.
DirtyDaveW
Dec 1, 2016 05:37 PM
jeff94z28
Sep 11, 2002 02:01 PM
Stumper66
Jul 9, 2002 01:42 AM
2_shady
Jun 30, 2002 11:24 PM
