Synthetic Oil?
Old Oct 1, 2003 | 06:55 PM
BlakeW5's Avatar
Synthetic Oil?
Could I safely put synthetic oil in my car without it getting leaks? It has around 74K on it, don't know for sure, new gears were added and the previous owner drove around for awhile without the speedo programmed.
Old Oct 1, 2003 | 08:24 PM
Terran2k's Avatar
assuming all your seals are good, the synthetic will not create any new leaks.
Old Oct 1, 2003 | 09:15 PM
jasons93z's Avatar
yes
Old Oct 1, 2003 | 09:22 PM
BlakeW5's Avatar
I'm currently using 5w30, should I switch if I change over to synthetic, or should 5w30 still work?
Old Oct 1, 2003 | 09:34 PM
ROADRAGE's Avatar
stay with 5w30
Old Oct 1, 2003 | 09:35 PM
JetLag's Avatar
Just go for it
Old Oct 1, 2003 | 09:39 PM
jasons93z's Avatar
use 10-30
Old Oct 1, 2003 | 09:48 PM
ROADRAGE's Avatar
Originally posted by jasons93z
use 10-30
why, thinner is better
Old Oct 1, 2003 | 11:18 PM
Kataklysm's Avatar
Thinner is not always better, use the 5w30 because thats what the car calls for. If you burn oil then you should use 10w30 same with if you have any leaks.
Old Oct 1, 2003 | 11:20 PM
Got-LT1's Avatar
i use 5W50 Castrol syntithic (sp?) in my car, no problems, runs better than when I had 10W30 in there.
Old Oct 2, 2003 | 02:47 AM
Seal's Avatar
where is it exactly leaking from? (ie head) or just of the pan or something?
I wonder if i'm leaking, but in the morning i see no oil spots
Old Oct 2, 2003 | 04:50 AM
slowpoke96z28's Avatar
i've got 190,000 miles on an LT1 and i use royal purple 5-30. no leaks, doesn't burn any oil, and i drive it like i stole it.
Old Oct 2, 2003 | 06:16 AM
Smoke T/A's Avatar
Originally posted by FlyBono24
Not sure, but the spots of oil on the driveway were around the back of the engine.... I didn't have time to pinpoint it, but everyday the spot was getting smaller. After about a week it had stopped altogether.
Sounds kinda like the famous rear intake leak. Dunno usually cars do not seal there own oil leaks.
Old Oct 2, 2003 | 06:57 AM
Kataklysm's Avatar
Its possible if the leak is small enough, the oil impurities could plug it up, with synthetic it would be very odd since it has less impuritues in it.
Old Oct 2, 2003 | 08:22 AM
S.J.S.'s Avatar
Hey Blake.....I believe in the old saying..."if its not broken, don't fix it." Why do you want to switch to synthetic at 75k and risk a leak when you car is fine now? Just because its the in thing to do? As long as you change your oil ever 3k you'll be fine. JMHO
GOOD LUCK
