Where is the factory keyless entry brain at????????
I just bought a security system accessory from gm that you can hook up to your car if it has keyless entry(which i do). So i need to locate it so i can tap into it
Originally posted by Fastbird93
I do believe that it's under the passenger side kick panel.
Originally posted by shoebox
Yes. right here through 1995. 1996-97 is integrated with the BCM.
thanks for the pic, do u happen to have a write up on this "project"
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
