Oxygen Sensor Removal!
Old Oct 1, 2003 | 06:11 PM
WhiteBeast's Avatar
Exclamation Oxygen Sensor Removal!
Ok, So what would be the easiest and quickest way to remove the right side (passenger side) oxygen sensor on an 95 Pontiac Trans Am LT1.
Also, what type of time frame am i looking at to replace it? I basically only have about an hour work time in the shop and this is also with a lift.
Old Oct 1, 2003 | 06:18 PM
madwolf's Avatar
Don't think there's an easy way to do that sucker.
They're usually stuck in there pretty good...some you can't take out even with a torch!
So for me, doing it from the top was out of the question. I had to do it through the bottom. Dropped the y-pipe and starter.
There might be an easier way but that's the only way that worked for me. I also heated it up pretty good with a propane torch.
Good luck!
Old Oct 1, 2003 | 06:25 PM
WhiteBeast's Avatar
So when you drop the y pipe, do you also have to move the entire exhaust system back to get the y pipe off? It looks like the rear cat back system is overlapping the Catalytic converter.
Old Oct 1, 2003 | 06:26 PM
madwolf's Avatar
No, you can just unbolt it at the converter flange and it will come off.
Old Oct 1, 2003 | 06:31 PM
ead94z28's Avatar
I did it from the bottom as well. I didn't have to drop the Y though. I used a long extension with a swivel. Took me a while to square it off on the head, but once I did it came right out. Helps alot if you let the pipes warm up a little. Good luck!
Old Oct 1, 2003 | 06:32 PM
madwolf's Avatar
Is yours an automatic?
Old Oct 1, 2003 | 06:34 PM
ead94z28's Avatar
Yes.
Old Oct 1, 2003 | 06:35 PM
madwolf's Avatar
Yes.
Weird... it didn't seem possible to me. I just didn't have enough room to turn the wrench.
Old Oct 1, 2003 | 06:38 PM
ead94z28's Avatar
I used a very long extension which allowed me to turn it below the Y. It took me about an hour.
Old Oct 1, 2003 | 06:54 PM
WhiteBeast's Avatar
Ok, So i am basically looking at about an hour to do all of the work right? Plus i have the advantage of having the work done on a lift.
Would i have to remove the starter as well? or would i be able to remove the O2 sensor with just the y pipe removed?
Victor Lamb
Aug 26, 2017 02:52 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
