View Full Version : LT1 Based Engine Tech
- Question Concerning The Water Pump Seal???
- Could a hole in the muffler ruin dyno and 1/4 mile times?
- steering noises and more, please help
- Which FREE mods are worthwhile ?
- Speakers
- Electric WP not running for 5min....damage?
- Part # for Fuel Pump?
- Fuel line Question
- Electric water pump, I have a question.
- Best Place to buy a Yank or Vigalante converter
- I'm So Excitied!
- Gas tank possibly sugared, what to do?
- 9 hrs. work STILL CAN"T GET THE TRANNY OUT!!!! PLEASE HELP
- LTCC set up
- Running temp\bleeding the system??
- Stainless Steel Brake Line Install?
- Will I need a Y-pipe?
- Getting rid of AIR .......completely
- hans feustel contact info?
- LT1 into 93 Jeep wrangler
- Subframe Connectors
- Mechanic Baffled!!??!?!?1
- Does anybody make these wires??
- Mr. Shoebox = Mr. Master of Part Location... question!
- Comp. Eng. Shocks
- Question about SS hood??
- can i use a .....
- Cam install question
- Dyno numbers on my almost stock 97 A4, these good?
- Every Hear Of South Side Machine Sup Kit ?????
- Pretty damn severe high rpm miss, feels like the rev limiter but isn't...
- I think I blew a head gasket; did not retorquing my ARP head bolts cause it?
- LT1 383 crate in summit!
- power window conversion
- What to do with starter wires in LT install
- Lt1- 5.7l,mfi,ho
- what is the temp when the fans turn on?
- LT4 Hot Cam prices?
- will this plug wire fitting fit my LT1??
- Connector on back of manifold broke???What is it??
- Quick... Hooker will directly bolt up...
- T56 guys.... How easy is it to accidentally tap it into R instead of 5th??
- Valvetrain Noise and Adjusting 1.6 RR's
- Thump! under shifter
- LS1 Brake Question
- 1.6 RR guys , more oil in the TB?
- Bad fuel pressure regulator?
- Mickey Thompson Et streets
- How much does it cost to fix driver side power window
- Fired up my new 383, now it has a weird clutch problem
- Inline fuel booster pump question
- Optispark Disassembly, need serious advice
- It died and Im getting 20 psi of fuel!
- SLP vs MAC headers
- lca's?
- 355 numbers
- Radiator Hose connected to the throttle bottle
- Air/Fuel Ratio
- Moser, brake fitment ???
- With my mods, how much hp should I see from these heads?
- 396 guys inside
- Raising RPMs
- Bangs rattles squeeks.. argh!
- Thermostat ?
- Flashing SES?
- Will a 15x6 draglite XP fit the front of my Z ?
- Need part # for stock LT1 timing chain
- Faulty Camshaft?
- is this just a waste
- Is my 4000 stall too big or too small
- Air/Fuel Ratio
- Installing motor from top with inake on???
- Do Fluidamper's come w/ hub also???
- Auto Trans issues. Whats the problem?
- getting service engine light(code information inside)
- First lt4 mod
- how can you tell if there's water in the oil?
- needles on gauge cluster?
- Got the car dyno'd yesterday
- What applications require pushrod guideplates?
- coolant problems
- Antoher New Best Today
- I need a new starter
- removed coolant restrictor valve thing on heater hose
- car is running lean I feel.
- Everybody with aftermarker or replacement CATS!
- Best tires for <100/each
- Leak in the A/C, any ideas?
- Parts need for header install?
- I've been reading Trans-Go kits are bad???
- 13.74 in a bone stock 95 Formula!
- wheel hop..
- Hooker Cat Back HP gains??????
- Is this my shift fork causing this?
- how bad is it to run a car on 7 ?
- i need to know where i might find some afr heads for a LT1??
- Breaking in an Engine
- remote start ses light
- SLP "Ultra-Flo" exhaust manifolds
- HELP suger in the gas tank
- E-Mail Address for DAL
- Fuel Pump?
- Autotap advise please...
- new gauge cluster?
- What Switches Do I Need??
- My Hotcam Kit........
- guys with TCI Vacum modulator(OBD1)
- So, I go to the track friday night....
- '96 SS pcm different???
- Need Help Installing An In-Line Fuel Pump
- Anyone want to look at my autotap file?
- Need help with codes I have.
- how much freon and oil to put in my car?
- installing air/fuel gauge
- Do strokers REALLY run quicker?
- Differences between a DynoJet and a Mustang dyno?
- Couple Power questions
- headers were glowing red last night
- I need a new battery...... What one?
- Wht The ****!!!!!!!!!!!!!!!!!!!!!! Opti And Ignition Module?
- Another Exhaust Question
- Cheapest place for nitrous bottle?
- Hypter tech, Worth it?
- SPEC e-mail or web address?
- fuel injectors?
- Battery relocation questions
- y coated headers
- Line Lock problem
- Water Pump Replacement Guide
- Diagnostic Plug on Swaped Datsun 280z
- tci 2800 stall
- 96 formula running bad
- Best price on LT4 conversion , source?
- Where can i get an overdrive Alt. pulley?
- Cat converter 93Z quick question
- 94 F Body Suspension Setup
- Electrical problems when raining
- tranny, clutch? I dunno
- Passenger side LT from the top?
- what could cause code 154?
- Shocks...what kind?
- brake light
- Thanx
- Best set of wires for OVC
- EST 1/4 mile times?
- How do I get my hooker 1 3/4 long tube headers in easily
- Dyno people: Get in here!!!
- Seriously aggitated
- Went in 1st instead of 3rd!
- where 2 buying headers monday
- Trey - Got a question for you from about a month back
- where to get strut mounts,fast?
- Driveshaft question
- indiglo gauges power supply?
- what suspension mod for rough ride.??
- 3 Angle Valve Job...any HP gains?
- Check out my Datamaster File....
- Many Problems Need some insight Please
- went to dyno today...
- where is the ignition coil on this car
- Possible on/off switch for pass air bag?
- Lacking Power
- Clunking on downshift?
- Pilot Bearing
- what should i run
- what the ****, now the car wont idle in closed loop
- Those with LT4 Hot Cam and auto tranny, how's your idle?
- horsepower diffrences between mustang and dynojet dynos
- Anyone Run dynatech 1 3/4 step to 1 7/8 headers
- which plug is better ngk tr6s or autolite 103s
- Someone dinged me, ideas for fix?
- 4 Tires to Choose From
- Cai and 1le
- Overheating
- camaro with C5 Vette Wheels?
- what should I get first?
- How to adjust 1.6 rr when the car is running...
- Magnaflow is on....
- IS this a WATER PUMP PROBLEM???
- Bleed all wheels after line lock install?
- could someone take a look at the times I'm running
- I got it going! no SES then the tranny started slipping and SES
- Thinking about getting a cam, need help!!
- Does yours ses light come on when the pcm picks up 11 degrees of knock?
- rear defroster
- Help, mating engine to bellhousing
- LT1 TPS Wiring?
- Question about coolant fans...
- 1997 Z with 5L?????
- Pro Kit versus WS6 springs
- Urgent my new motor won't fire up
- Difference in HP between stock plugs and 2 heat range lower plugs..
- Why is there a weap hole on our waterpumps?
- Gears finally going in....
- How do I.......
- Anyone know what's goin on?
- How do I bleed the brakes?
- Bolt for oil dipstick tube.
- What weight of oil will serve me well?
- weak 4th gear in 4L60E
- code p1133
- Poping out of reverse T-56
- tranny
- front end wiggles at low speed
- Massive Surging!!!!
- Anyone have a EST (electronic spark timing) control mod...
- how to align windows ?
- Car is taking longer to start or almost didn't.
- My A.R.E. installed 3:73s are getting louder
- Raising Rev Limiter
- AIR Pump & cold-start stumble
- Oil Filter question
- LT1 block casting numbers?
- Anyone have exhaust sound clips ?
- minus muffler
- need to know... Coil and the module.
- How to fix lifter tick??!!
- installing cat back exhaust
- those with offroad pipe plese enter :)
- Cant get ABS line off for line lock
- New user, and Firehawk owner
- How to get stock exaust off?
- Dynatech vs. Hooker Longtubes
- DIY LCAs?
- What 7/16 Studs are the way to go?
- Parts needed for replacing lifters??
- New #s!
- Best gaskets for slp dual cat headers
- Dyno sheet for stock LT1?
- What Size Injectors?
- can i still save my opti??
- True Dual Setup???
- Heads? Where to get, what kind
- what would cause this?
- Anybody know this about gears, good info
- intake manifold passages
- bad crankshaft position sensor (?)
- What is this part
- Anybody Ever Noticed This
- Went to the 1/8 th last night
- Cam with stock converter and 2.73s
- Shift Skip?
- Need immediate assistance...
- Software for Laptops for Diag,Info
- Auto Tapping results!
- HELP PLEASE!!! Those with street twin clutch!!
- car died outta nowhere, getting no spark
- Hey Injuneer inside please!
- Redline Line Water Wetter?
- Stumped!
