could someone take a look at the times I'm running
Old May 31, 2003 | 06:39 PM
NONO5.0's Avatar
Took the car to the track about 2 weeks ago for the first time since I did the hotcam kit upgrade and was wondering how these times seemed:
1.230 ---reaction--- .918
1.938 ---60 ft --- 2.711
5.962 ---330 ft. --- 6.570
8.152 -- ET@594 ft. 8.535
8.795 --- 1/8 ET 9.154
69.97 ---1/8 MPH -- 72.6
My second run was:
.502 ---reaction ---.655
1.506 ---60 ft --- 2.400
4.386 ---330 ft. --- 6.202
5.928 -- ET@594 ft. 8.136
6.382 --- 1/8 ET 8.741
99.12 ---1/8 MPH -- 74.46
This was with pretty much no traction thru 1 and 2nd gear. Could someone convert this and tell me about what I run in the 1/4? Also, do these times seem good for my mods listed below? I'm new at this and just wondering where I can improve (of course I know my first change should be tires!) Thanks for any advice!
Mods are:
LT4 hotcam kit and ported/polished heads M6 3.42s, Moroso CAI, 52 mmtb, LT4 knock module, !CAT, Flowmaster, TPIS shortie headers, 17 inch WS6 rims
Old May 31, 2003 | 06:50 PM
mjcent922's Avatar
Those times are GARBAGE LOLj/k You need to get some traction big time.2.7 & 2.4 short times are not even close to being good.Get some brg drags and work on those short times.You should be in the 1.7-1.8 range to be good.1 second better should get you about .5 or more in the 8th.
Old May 31, 2003 | 07:30 PM
sweet94Z's Avatar
Your 60ft sucks of course but your trap speed should be at least in the 84-88 range. Were you on the breaks early? If not then I'd get that thing on a scanner. Later.
Old May 31, 2003 | 08:47 PM
BackInBlackZ28's Avatar
That doesnt look to good at all my man. 2.7 60ft is REALLLLY BAD! Tires and a efw other sus. mods might help. Also practice your launch a lil more too. You should be able to run 12's in the 1/4 easy with that setup, jus a lil better driving. Good luck!
Old May 31, 2003 | 09:03 PM
Prorac1's Avatar
I ran a 13.70 @ 102 in the quater and on that pass i ran a 8.80 @ 80.08 mph. But i agree with the other guys, it sounds like you need tires, but your trap speed should be a little higher, look into some tuning. Hope this helps. Prorac1
Old May 31, 2003 | 09:04 PM
bad95z28's Avatar
you have got to make sure that you stay on the gas the whole way through the traps. i would bet some money that you were on the brakes too quick. there is now way you could run 8.74@74mph w/ a 2.4 60ft. you should be running low 8s w/ tires. you have a 12 second car i'd say.
Old May 31, 2003 | 09:14 PM
95 Silver TA's Avatar
Just as a reference, One of my freinds with a M6, hot cam, stock exhaust manifold, borla cat back and an Ed Wright tune was running 13.6. Then he installed a shift light and pratice his launch. Now he runs a consistent 13.0 to 13.1 at 107-109MPH. I would say get your launches down right and your shift points and you will see a big improvement in both your ET and 1/4 mi times.
hope that helps,
Claude
Old May 31, 2003 | 09:54 PM
NONO5.0's Avatar
Thanks for all the tips and info!
Feffman
Oct 9, 2015 05:42 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
