Bleed all wheels after line lock install?
Old May 31, 2003 | 06:48 PM
95_RipperZ's Avatar
Should I bleed them all or just the abs and master cyclinder inside the engien bay?
Old Jun 1, 2003 | 06:29 AM
slopokrodrigez's Avatar
Forget a bout bleeding them, I want to know how you're gona make a line lock work with the ABS in??????????
If you make it work let us all know how you did it please.
Old Jun 1, 2003 | 07:32 AM
Projectz28's Avatar
Moderator
you only need to bleed the front circuit, as the front and rear are 2 seperate systems.
Line locks work just wine with the ABS. Put it in and away you go. You will get a "brake" light when you use the lock. The ABS will see an abnormal pressure differance between the front and rear pressure sensors. Once you let off the lock, all you have to do is tap the brake pedal the the light will go out. The ABS is not active if you are not on the brake pedal.
Collector Car
Jan 5, 2015 10:58 AM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
squarehead
Nov 21, 2014 08:02 PM
