Speakers
Old Jun 2, 2003 | 11:34 AM
eagleknight97's Avatar
Speakers
How do you remove the front door speaker grills. I am able to remove the side clips but the top and bottom clips wont come undone and i dont want to cause any damage. And also, do any of you guys have different speakers in the rear, other than the stock 4 inch ones. Thanks alot in advance.
Old Jun 2, 2003 | 11:44 AM
norcalstreet's Avatar
You just have to mess around with it. They'll come out with a little fiddling.
Old Jun 2, 2003 | 12:12 PM
sirhc reuab's Avatar
the top and bottom are not clips, they will break off or you can just take the whole door pannel off, they will still go back on if you break them (well dont break them, use a razor blade to make a straight cut)
Old Jun 2, 2003 | 01:04 PM
CeeBee94Z's Avatar
I dunno what you guys are talking about, but both camaros I have owned are all clips and I have not broken one of them when removing....all that you have to do is flex it a little and the top and bottom should come out....unless of course some idiot glued them in.....
Old Jun 2, 2003 | 03:00 PM
fbird95's Avatar
There should be no clips breaking as stated above. They should come off nicely using little force. You do need to watch out for the mounting clips on the speakers next to the rear seats though. They sometimes fall off pretty easily.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
