Air/Fuel Ratio
Old Jun 1, 2003 | 09:34 PM
rghyland's Avatar
Air/Fuel Ratio
How do you convert the voltage from the o2 sensor to the Air/Fuel Ratio? Or is it to dificult to do?
Old Jun 1, 2003 | 10:52 PM
rskrause's Avatar
Moderator
Re: Air/Fuel Ratio
A stock O2 sensor is sometimes called a "lambda sensor". A characteristic of this type of sensor is that its' output suddenly changes when the AF ratio is richer or leaner than the stoichiometric value. With the sensor in an LT1, I think that ~470mV represents stoich. Whatever the number is exactly, it will increase rapidly to a max of ~850-900mV when the mixture goes richer than 14.7:1 and quickly down to ~100mV when it's leaner. As a result, it can only be used to determine if the mixture is at stoich, richer, or leaner.
A wide band O2 sensor has a much more linear response to changes in AF ratio. Using one of these, you can determine AF ratio over a wide range. Each particular sensor design will have a different response curve and you need to have this calibration to use it. If you have the calibration, it's easy. Here is osme more information which may be useful. http://vehicle.me.berkeley.edu/~markw/efi/SAE920289/
Rich Krause
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
Aug 7, 2015 01:26 PM
