Best gaskets for slp dual cat headers
Old May 31, 2003 | 12:05 PM
97ss150's Avatar
I have searched already. I get diff oppinions about well this one is good then someone else says they arent worth a damn. any ieas which ones i should get? i wanna do this install next weekend (6th-7th). any help is greatly appreciated
Old May 31, 2003 | 12:06 PM
96z's Avatar
96z
I would use felpro's.
Old May 31, 2003 | 12:09 PM
97ss150's Avatar
which ones? and im kinda curious about this header install. i think im going to do it at the same time i do my lt4 hotcam and s-trim. whatcha think?
Old May 31, 2003 | 12:20 PM
96z's Avatar
96z
The header install in pretty straight forward. Remove EGR, AIR connections to old manifolds, take of manifolds and do the reverse with the new headers.
I THINK the are Felpro 1036's. They are D port shaped for LT1's so get the "LT1 type"
What header bolts are you using?
Old May 31, 2003 | 01:20 PM
jkipp84's Avatar
Felpro 1406's are what you're looking for for D-ports.
Old May 31, 2003 | 02:38 PM
96z's Avatar
96z
Thanks for the back up, I knew it was something like that.
Old May 31, 2003 | 03:21 PM
Camaro_Maniac63's Avatar
Get a pair of Ultraseals from Autozone or someplace. I have the SLP Shorties on my 1997 Z as well, and those gaskets have worked great. Make sure you get some fire sleeving done around the PCM and the coil wire, or you might burn couple of the wires, or even worse, the whole passenger side of the engine compartment. I burnt a couple wires, but a guy with a 96 TransAm burned his PCM and almost the entire passenger side of the engine.
HotCam+1.6rr+Headers=haul-*** Z28
1997 Z28 30th Ann. Ed
Moroso CAI, LT4 HOt CAm w/1.6rr, ported and polished heads, Lt4KM, SLP Headers, !cats.
YellowTransAm350
Mar 2, 2003 03:38 PM
NED4SPD
Sep 16, 2002 10:45 PM
Thebeast431
Aug 25, 2002 05:06 PM
turbo_Z
Aug 19, 2002 10:50 PM
mysticslp2002
Jul 29, 2002 02:03 PM
