What weight of oil will serve me well?
Im going to be using the AC Delco PF35 filters, those are the large ones. I have a heads/cam LT1 with almost 90k on it and wondering what weight oil I should go with. Thinking 10w30 in the summer? 5w30 in the winter? I live in Colorado, so we have both extremes here.
Still cant decide if i want to switch to synthetic or a semi synthetic....think I might go with the semi synthetic from castrol, good choice?
well ****, autozone said ac delco discontinued the PF35 filter? Is this true? Any other AC delco that will fit on the lt1 besides the pf25 (too damn small)? Want a large filter. And the k&n are so damn expensive....
Fram makes good filters. It's all i've ever used, never any problems. And if you get "in the zone", they should be able to cross reference it for you. I use 10-30 summer, 5-30 winter. 20-50? Save it for your 9 second race car. I can't tell you how many clowns i've seen use 20-50 in January, for their street car. "Well it keeps the engine cooler." "uh.., ok."
Originally posted by thewinner
Fram does NOT make good filters. they have cardboard endcaps.
Don't mean to be an ***, but how is this a bad thing? I mean if you change it at the right intervals, it should be ok, right? Even if the cardboard broke up (still not sure if this is true, but lets go with it), wouldn't the, uh...FILTER CATCH IT?
Originally posted by SDAKOVIC
the deep filter from g.m. is now #1218
Re: What weight of oil will serve me well?
Use 5W-30 synthetic and you should be fine.
Rich Krause
Noct
05-26-2016 10:26 AM
carguy0119
04-11-2016 11:11 PM
cmsmith
04-10-2015 10:03 AM
bossco
11-29-2014 10:18 AM
