How do I get my hooker 1 3/4 long tube headers in easily
Raise the car atleast to a set of ramps. Take off the starter, oil filter,dipstick tube etc, basically anything in the way of getting them in.
The passenger side will be the hardest and you will have to undo the through bolt on the motor mount and raise the motor a couple inches to get it to go in. The driver side should just slip in.
The higher you get the car the better.
ehh
raise car 2 feet, remove oil dipstick, starter, altinator, steering linkage, old manifolds, AIR pump, EGR stuff. both slide right in from the bottom, simple.
i was told to remove oil filter and jack the engine, this was not needed.
Originally posted by wannaracez28
It looked like on the driver side i would have to take out the brake booster.?
Plugs need to be out also.
stockssn2o
May 25, 2015 08:54 AM
