I need a new battery...... What one?
Old Jun 1, 2003 | 11:39 AM
Xride's Avatar
Ok I need a new battery, I had my car tested the other day and was told that its not holding charge very well.... this would fit with the hard starts the longer its been sitting. I went and looked but I have no idea what one to get, I was jsut going to get the optima red top I think it was, cause it was red to go with my car, but they also had the yellow top, and there was other batteries as well, whats a good battery to jsut start my car, I dont have a system, and never will.
I jsut want to do this right this time and not have to worry for a few more years.
Old Jun 1, 2003 | 12:02 PM
burnemonm1's Avatar
i have a red top it works great the yellow is a little better but the redtop should do it just fine. and I also have a system and it holds the charge very well.
Old Jun 1, 2003 | 01:28 PM
texasTA's Avatar
the red top is used for everyday use, whereas the yellow top has a deeper cell which aids in the use of large stereos , extended use,etc...
Old Jun 1, 2003 | 02:00 PM
Xride's Avatar
ok, So I can save some of my money and jsut get the red top and be good. thanks for the help.
Old Jun 1, 2003 | 03:12 PM
Xride's Avatar
Originally posted by ArcticYT95TA
How much is the red/yellow top battery?
I don't know much about these...I just have a regular Autozone battery on my car, haven't had any problems with it. Oh, and no system here either.
the place I was looking it was 120 for the red, and 145 for the yellow, and 100 for a normal black somebrand or another, Canadian money. I have a generic battery now, and it doesnt look nice either. So I'm going to do it right and get a good one that looks good too.
Old Jun 1, 2003 | 03:15 PM
LWillmann's Avatar
I paid $75 for a Duralast Gold 900 CCA battery from Autozone. Should be fine... No need for anything fancy to start the car unless you want something for looks.
Old Jun 2, 2003 | 03:21 PM
burnemonm1's Avatar
**** looks like I'm going to canada to buy my batteries
Old Jun 2, 2003 | 04:05 PM
ssz28's Avatar
Only 120 can. for an Optima? Good deal. It may cost more at first, but they WILL last longer than a normal battery. With an Optima, it can withstand going dead more times than a regular battery. It can also handle the high heat under our hoods better than the regular ones as well. It's a terrific battery that I would recomend to anyone, and it's not just for looks. Don't waste your $ on a yellow top. They won't last as long as a "starting" battery. They are designed for large electrical loads, so unless you have a stereo, get the red top.
Just some other info, Optima red tops last at least 4 - 5 times longer in the desert on generators than the normal batteries. That has gotta say something about their quality.
Old Jun 2, 2003 | 04:47 PM
96 WS6's Avatar
You want a red top... that is the best starting battery. The yellow top is meant to be discharged and recharge quickly (ie, you would put yellow tops on a car with hydraulics or throw them in the trunk for a fat system). I have a red top and it's beatiful, first crank starting every time.
