Difference in HP between stock plugs and 2 heat range lower plugs..
I'm wondering about what horsepower difference would it make if I run 2 heat range lower plugs on an N/A car. (Right now I have Autolite 103 gapped 0.045") Would it be better to go to NGK TR6s? My car should be making about 400 RWHP N/A and I plan to spray a 100 shot sometimes. (not very often though)
Thanks.
Thanks.
Originally posted by BAD 97 WS-6
I saw 2 tenths and 2 mph difference....same day test at track. Iam running high compression (11.2) so thts why the colder plug helped me. I stick with autolite 103's
Originally posted by rskrause
There will be abslutley no difference in hp unless the plugs foul and it misfires, which it should not.
Rich Krause
Rich Krause
Me and 2 buddies were running nitrous a few years back. We all went to the track to get some track times before running the nitrous. We were all using the stock heat range without the nitrous on. Once we went back to run the juice, we switched to 2 heat range colder plugs. All the cars ran 2 tenths slower with the cold plugs and smaller gap. Once we kicked in the nitrous, we really didnt care though!
I could see a difference if the hotter plugs were causing KR but if you are not getting KR, the colder plugs "should" make the same power but take longer to foul in my opinion.
If you can not check for KR or if you are getting KR, that might eliminate it and help you out some.
Maybe some of the dyno tuners could shed some more light on this and answer the question better.
NighTTrain66
NighTTrain66
HectorM52
Jan 31, 2015 07:29 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
