What to do with starter wires in LT install
Old Jun 2, 2003 | 01:44 AM
revtime's Avatar
I have these wires real close to the headers, what did you guys do with them? I relocated my ABS wire so its cool but the loom with the O2 wires and starter wires is in harms way can I just wrap them with Thermo Tec heat tape? That is what I used on my fuel lines.
Old Jun 2, 2003 | 09:47 AM
thewinner's Avatar
extend them and route through the motor mount
Old Jun 2, 2003 | 11:57 AM
94 NO TOP Z's Avatar
I lenghted all those wires also so they went around the front of the header and then down below.
Old Jun 3, 2003 | 08:34 PM
revtime's Avatar
What gauge wire did you use? I don,t want to use the wrong wire.
Old Jun 3, 2003 | 09:03 PM
97FormulaWS-6's Avatar
I believe 10 gauge should work fine for the trigger wire, the large battery cable was long enough on mine.
I extended mine with some 8ga that I had laying around, and moved all the wires to route along the AC lines, then through the motor mount.
Old Jun 3, 2003 | 09:52 PM
96speed's Avatar
That's what I did.
Ryan
jayvar
Feb 2, 2015 10:00 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
GigaMp3z
Feb 20, 2003 02:57 PM
CobraEatr
Jul 23, 2002 06:32 PM
