wheel hop..
wheel hop..
sometimes if i launch hard the car starts to shake and the back end feels like its hoping is there anyway to fix this? it did this before all stock and after the sportlines and new shocks.. im going to be putting relocation brackets and subframes connectors there sitting in my room will they help this problem..?
Get some traction bars, this should put a stop to the wheel hop. Just be happy you have a Camaro, the wheel hop isnt too bad. First time i road in a newer Cobra i stared laughing at how bad the wheel hop was, i seriously thought something broke.
Do NOT put traction bars on a 4th Gen torque arm suspension.,.. you will put the entire rear suspension in "bind" and tear something apart if you have enough power. No way to compare the problems that you find in the recent Cobras with their IRS... two vastly different suspension systems.
Wheel hop becomes a problem when the body end of the lower control arm drops below the axle end of the arm. That causes the LCA to push the body down, which means the reaction at the other end of the LCA is trying to lift the axle up.... the axle comes up, you lose traction, the body comes up, and the whole cycle starts over again... hop.... hop... hop.
With Sportlines (2" drop?) you are going to have big problems no matter what you do.... lowering and drag racing aren't really compatible. But, you can help by 1) installing the LCA relocation brackets to keep the axle end of the LCA lower, and 2) adjustable shocks, or an airbag in the passenger side coil spring to keep the body from squatting too much.
If everything is in working order an F-body (82-02) shouldn't have any wheel hop. Wheel hop is caused by axle wrap and the torque arm axle shouldn't have any of that! Most wheel hop is caused by bad shocks or worn bushings.
I have had 8 F-Bodies and have yet to incounter wheel hop. Make the suspension work right stock before you mod it.
You also might want to read through the discussion on the Advanced Tech board on "Instant Centers"... includes several posts on "anti-squat" geometry.
Hmmm, Injuneer, you make some good points. I used to have an '84 Firebird (about 10 years ago) that I had converted from a 2.8 to a 350/turbo350 and with the stock wheels and tires (215 65 15's) I could spin the tires through all three gears and make it only about 30 feet until I'd let off to grab and go (even then I'd have to let off a few more times to straighten out) . So I intalled some 295 50 15's hoping the added traction would solve the spinning (had 3.23 rear gears IIRC) and then the darn thing would hop so bad I thought the rear end was going to take off out from under the car . I totaled the car though before I ever got to figure it out. My plan though was to go with SFC and tubular LCA as the next plan of attack, even though I had liked to think that my engine I had built was just too darn powerful . Man I still miss that car
my car did the wheel hop when it was stock suspension and does it now the the sportlines and the 20's and new shocks... i dunno maybe some crap is broke somewhere or something. and btw i pulled a 1.9 60ft with the sportlines.. so they work fine for drag racings as a matter of fact i had the best 60's out of all the fbodys at the track that day and was the fastest lt1 for somereason even though some had alot more mods than mine does that the moment everything is waiting to be installed.. i also smoked a 2000 z with no cats 6speed intake exhaust chip etc. so idont think they hurt.. i need to find out what this wheel hop madness is, it only does it sometimes
SOUTH SIDE MACHINE SUP. KIT for Camaro, Firebird, T/A's, (Kit includes bars, crossmember,sub-frame, connectors, driveshaft loop, and all reinforcements, straps and gussets.)WILL SET PINION ANGLE, 93-98 Camaro, Firebird, T/A's (including convertibles)FOR CAR WITH 500HP AND UNDER
check out there web page at http://www.southsidemachine.com/gm.shtml
THIS KIT IS ABOUT 600-700 NEW AND THIS KIT HAS NEVER BEEN USED:ILL SELL IT FOR $450
BUT IM THINKING OF PUTTING IT ON MY CAR I GOT IT FOR A GIFT BUT IM NOT SURE IF I WANNA GET IT PUT ON IT WILL COST 3-400 TO GET INSTALLED AND IM THINKING OF PUTTING IT ON MY CAR BUT HAS ANY ONE SEEN THIS KIT ON A CAR OR DOES ANY ONE HAVE IT ON THIER CAR WHAT KINDS OF GAINS WILL I GET AND WILL IT MAKE THE CAR RIDE REALLY BAD OR MAKE IT BETTER TO RIDE IN, THIS IS JUST MY EVERYDAY CAR
ALSO I HAVE 4.10S
ALSO I HAVE 4.10S
NOW WHAT I SAID I WANT TO INSTALL ABOVE POST IS THAT WHAT YOUR SAYING NOT TO DO???
There are people pulling 1.2x 60-fts' with "stock style" torque arm suspension, and no "traction bars"..... the people who tried the Lakewood stuff found they ripped the bars apart under heavy load. Don't know about the Southside stuff..... but if Madman doesn't need it, Baxter doesn't need it, SLED doesn't need it, it probably isn't the hot set up.
this didn't really help me you don't know anything about it never seen it and your saying don't use it, but you can't give advise if you don't know nothing about what this is so...does any 1?
30th Anniv Z28
08-01-2015 10:39 AM
jasonduaine
06-04-2015 09:29 AM
