Mickey Thompson Et streets
Originally posted by InjectedSS
no its 26in TALL and 16 inner diameter
Whats the maximum size one can run without tubbing? (exact specifications)
Can't beat that dragged out rwd look. Heh.
No tubbing required. That tire is only just a little larger than the 275/40/17. Mainly height difference. You can also go to a 28 inch tire on a 15'' rim but some wheel well massaging may be required.
Any caliper modification required?
Originally posted by Ghettoraid
What offset wheel gets you the most width without going outside of the wells?
How big a wheel/tire can I fit?
I really want a pair of these...
http://www.jegs.com/cgi-bin/ncommerc...78&prmenbr=361
(i.e... largest size with little to no modification..)... exact specifications
Could probably handle tubbing... i've got a friend who could do the welding but...Nah.
