Every Hear Of South Side Machine Sup Kit ?????
SOUTH SIDE MACHINE SUP. KIT for Camaro, Firebird, T/A's, (Kit includes bars, crossmember,sub-frame, connectors, driveshaft loop, and all reinforcements, straps and gussets.)WILL SET PINION ANGLE, 93-98 Camaro, Firebird, T/A's (including convertibles)FOR CAR WITH 500HP AND UNDER
check out there web page at http://www.southsidemachine.com/gm.shtml
THIS KIT IS ABOUT 600-700 NEW AND THIS KIT HAS NEVER BEEN USED:ILL SELL IT FOR $450
BUT IM THINKING OF PUTTING IT ON MY CAR I GOT IT FOR A GIFT BUT IM NOT SURE IF I WANNA GET IT PUT ON IT WILL COST 3-400 TO GET INSTALLED AND IM THINKING OF PUTTING IT ON MY CAR BUT HAS ANY ONE SEEN THIS KIT ON A CAR OR DOES ANY ONE HAVE IT ON THIER CAR WHAT KINDS OF GAINS WILL I GET AND WILL IT MAKE THE CAR RIDE REALLY BAD OR MAKE IT BETTER TO RIDE IN, THIS IS JUST MY EVERYDAY CAR
the south side kit throw's away the torque arm and lower control arms.
Friend has it on a 3rd gen,it rides good,but in his car the pinion angle is fixed when the southside bars get welded on.
Basically they are like a non adjustable ladder bar setup.
Also,if you run this setup,most "stock suspended fbody" races wont let you come and run,due to no torque arm.
A buddy of mine had the south side machines kit on his 86' camaro, and it planted the rear real well, the problem was like RancinLT1 mentioned above, a lot of places wont let you run your car in a stock class. For my buddy it didnt matter cause he had just headers with extensions dumping into NO exhaust, so he could run anyway.
finally i have some people that heard of my kit. i got the kit for like 250 off i friend that needed money for his new kid on the way i would like to hear more from any one else that know about this kit but does any one know of the kit for my car 4gen? please tell me all thanks
I have heard of the kit on 4th gens yes, but not too many people use it, from what i understand due to tracks cracking down on what class you can run in with your car like before mentioned. A lot of other people use other traction bars like Lakewoods, so i am surprised that there arnt more replies. I only have seen the kit in person on 3rd gens so i cant help in that area. I think it will help a 4th gen alot, cause they have a more clunky rear end then 3rd gens in general. You should be able to contact the south side machine people with any specific questions. Sorry i cant really help you out too much
I DON'T THINK THIS KIT THROWS AWAY THE TORQUE ARM
ANY ONE ELSE KNOW MORE ABOUT THIS KIT???
