Anyone have a EST (electronic spark timing) control mod...
Old May 31, 2003 | 03:32 PM
yorkie's Avatar
Anyone have a EST (electronic spark timing) control module
go bad, what did it do? How can you tell if you have a bad one?
Eric
Old May 31, 2003 | 04:52 PM
thewinner's Avatar
wtf u talking about? lol
Old May 31, 2003 | 05:00 PM
yorkie's Avatar
right above the coil there is a module...
It is called the EST. Electronic Spark Timing control module, as stated in my book.
Old May 31, 2003 | 05:04 PM
yorkie's Avatar
some people call it a ICM Ignition Control Module..
My book says EST module.
Old May 31, 2003 | 08:35 PM
yorkie's Avatar
ttt
ttt
Old May 31, 2003 | 08:44 PM
RUFFIDLNZ's Avatar
If it goes bad your car will not start
Old May 31, 2003 | 08:50 PM
yorkie's Avatar
thanks...
Either good or bad then.... Looks like mine is good.
Old May 31, 2003 | 11:45 PM
96ZRDR's Avatar
The Electronic Spark Control is the same as the knock sensor. If it is bad, it will definetely set off a code, and automatically pull max timing, and kill your horsepower.
Old May 31, 2003 | 11:48 PM
xxsaint69x's Avatar
and how can u mod it ?
lol
Marcin
Old May 31, 2003 | 11:50 PM
yorkie's Avatar
Mod... or module
It is not the same as the knock module or sensor. It is just above the coil and attached to a finned aluminum bracket that is on the drivers head, take a look.
Old May 31, 2003 | 11:53 PM
xxsaint69x's Avatar
Re: Mod... or module
he was just comparing it to the knock sensor...u will know if they go bad, since your car will be a lot slower then usual.
Btw...i thikn u are talking about the ingition module
Old May 31, 2003 | 11:54 PM
yorkie's Avatar
It is called a EST, in the gm fuel injection book
I have sitting in front of me, EST is Electronic Spark Timing.
Old May 31, 2003 | 11:56 PM
yorkie's Avatar
IT IS NOT the same as a knock sensor
The knock sensor and the est are two different components.
Old Jun 1, 2003 | 08:31 AM
Re: It is called a EST, in the gm fuel injection book
It's not called that on an F-body. The modue is the Ignition Coil[Control] Module (ICM). The circuit is the ignition control circuit.
ESC is the knock sensor circuitry, but he said EST not ESC.
Old Jun 1, 2003 | 12:07 PM
yorkie's Avatar
well reading this right out of a book
EST Electronic Spartk Timing, it covers tuned port and the lt-1. Guess the book is wrong ICM then..
