Stainless Steel Brake Line Install?
Old Jun 2, 2003 | 09:58 AM
akrott1's Avatar
Arrow Stainless Steel Brake Line Install?
Just picked up the Earl's hyperfirm stainless steel brakeline kit and was looking for anyone that has installed this on their 93-97 LT1 Car.
Any special tools required?
Did you run into any specific problems?
Anything to watch out for?
Install guides?
Thanks,
Aaron
Old Jun 2, 2003 | 10:01 AM
joeSS97's Avatar
i just did it a couple weeks ago.Pretty easy to install.Just make sure you use the right size line wrenches.And some good penetrating oil.
Old Jun 2, 2003 | 11:49 AM
gstaehle's Avatar
I agree with joeSS97. When I put the Earl's on my 96Z I blead only the wheel cylinders and had a very low pedal. The book recomends bleeding the ABS hydraulic modulator first. First the Rear ABS Bleeder then the Front ABS Bleeder (This is called Priming the ABS hydraulic modulator). After this go to the furthest wheel, Right Rear, Left Rear, Right Front then Left Front. After that I had no problems.
Jazsun
Dec 29, 2014 12:14 PM
Dec 17, 2014 11:00 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
squarehead
Nov 21, 2014 08:02 PM
