Fuel pump not shutting off after prime w/ engine off
I'm still trying to figure out why my fuel pump (from a 95 F150) doesn't shutoff like most cars when you first turn the key and it builds up pressure then stops. Mine keeps going and you can hear the fuel going back into the tank. Anyone know what's wrong? I thought of putting my finger over the outlet on the pump to see if it'll stop pumping...
Originally posted by kevmor99
It's completely seperate, the relay is just switched on by the ignition and it turns the pump on, but isn't there some sort of pressure switch in the pump to turn it off?
Oh ok, the reason why I bypassed it was because I thought it wouldn't give it power without having a theft deterrent module and the rest of the stuff hooked up. How does it know when to shut it off?
When you first turn the key ON and the pcm gets power, it energizes the relay for 2 seconds and then shuts it off. If you go ahead and begin to crank the engine, the pcm monitors for pulses from the opti. When it sees them, it turns the relay back on.
Ok, thanks!
Ok, thanks!
10-31-2016 11:09 AM
