Question about light over the spark plugs
Old Oct 11, 2003 | 11:48 PM
luis nunez's Avatar
My car has a very, very slight rough idle, but doesn't have any problems when I am driving it, I know I am a bit picky with my car but it is a very little rough idle, last night I saw some little lights over 1 or 2 spark plugs are those lights normal? I also notice that the batery gauge is a bit lower than normal this is happening when I have the air on...
Maybe the lights are my problem? I also have a very bad header leak,that I will fix this monday, can that also cause a rough idle also?
Old Oct 11, 2003 | 11:54 PM
bad96firechikin's Avatar
I'm not sure I understand your question. There are no lights above the spark plugs.
Old Oct 11, 2003 | 11:55 PM
dkeers's Avatar
It sounds like your plug wires are arcing. That can cause a rough idle. They could have got burned on the headers, or worn down by rubbing against something. Also, If your wires touch each other the spark can arc between them.
Dustin
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
94z28jbw
Sep 8, 2002 03:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
