Car starts and dies
Old Oct 13, 2003 | 09:59 PM
Taylor's Avatar
Car starts and dies
My 93 will start up and then die, sometimes it will start up just fine and run fine, other times I can get it started and rev it up but it wont idle and runs kinda rough. I have replaced the plugs and wires, The plugs are getting spark. Do you think it could be the ICM??
Taylor
Old Oct 13, 2003 | 10:56 PM
Zpower's Avatar
could very much be. when my icm took a dump, the car would turn on but wouldnt go over 3k rpm's. it would die as soon as it hit 3k. in D or in P. if you have a friend with an lt1 swap coils with icms to see it if fixes it.
Old Oct 14, 2003 | 09:42 AM
Taylor's Avatar
I dont have any friends that have 93 LT1s. Can I use one off of a 94-97?? They have a different part number than the 93s.
Taylor
Old Oct 14, 2003 | 12:55 PM
Taylor's Avatar
Does anyone know if I can put a 94+ ICM in my 93??
Taylor
Old Oct 14, 2003 | 07:21 PM
Taylor's Avatar
Anyone?????
TTT
Old Oct 14, 2003 | 07:28 PM
shootcallerz28's Avatar
icm
No you can not i just bought one i am haven same problem this week i replaced the coil.Icm.fuel pump regluter still have the problem but there a differce in the icm get one for a 93 good luck if you find the problem out let me know the same here
Old Oct 14, 2003 | 09:48 PM
Taylor's Avatar
Ok now the car doesnt even start, it will act like it is going to start then backfire. I havent gotten to try a different ICM yet, but I know the plugs are getting spark. I bought this car about a month ago, it ran bad so I replaced the plugs, 3 were orginal with 118,000 miles on them, it ran great after that, then it started to miss so I decided to change the plug wires and the exhaust manifolds leak so I figured take them off and replace the gaskets and plug wires at the same time. So when I was doing that I found one or two plugs that were backing out so I figured that was the problem, well I got it all back together and it wont start. I check the wires and they are in the correct spots, I did them one at a time. I cant figure this out, I guess tomorrow I am going to buy a new ICM.
Taylor
Old Oct 14, 2003 | 11:40 PM
Zpower's Avatar
i know that a 94 coil/icm will work on your 93. we took the coil with icm off my friends 94Z and put it on mine. it it fired right up.
so i think other years could work too?
after a while my car wouldnt start either. sounds like we have the same problem.
Old Oct 15, 2003 | 01:14 AM
Fatdog's Avatar
Cool
Idle control valve may need cleaning.It's that brass looking thing ,round,on the left side of the throttle body.Hope this helps.
Old Oct 15, 2003 | 01:48 AM
mickeyiz28's Avatar
man that sounds EXACTLY what happened to my car a couple of months ago, it was the icm, i bought one from napa and put it on it did the same thing, turns out that napa sold me a bad icm, and it took me a month to figure out that the one they sold me was bad
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
